Balanset-1A: Your reliable balancing assistant
Rozmowy towarzyskie i tematy nie mające nic wspólnego z motoryzacją.
Jeremydwert
Postautor: Jeremydwert » 29-08-24, 23:32
Balanset-1A: Your Universal Tool for Balancing and Vibration Diagnostics
Description:
Order on Amazon
Balanset-1A is a compact and powerful tool allowing for dynamic balancing and vibration analysis in the field. It is ideal for balancing a wide range of rotating equipment, such as crushers, fans, mulchers, straw choppers on combines, shafts, centrifuges, turbines, and much more.
Features:
Vibrometer Mode:
Tachometer: Precise rotational speed measurement (RPM).
Phase: Determines the phase angle of vibration for subsequent analysis and balancing.
1x Vibration: Measurement and analysis of the primary frequency component.
FFT Spectrum: Provides detailed information about the vibration frequency spectrum, allowing for the detection of various issues.
Overall Vibration: Measurement and monitoring of overall vibration levels.
Measurement Log: Stores the measurement history for convenient analysis and tracking of changes.
Balancing Mode:
Single-Plane Balancing: Eliminates static imbalance.
Two-Plane Balancing: Eliminates dynamic imbalance.
Polar Plot: Clearly displays the imbalance and helps accurately determine the location for corrective weights.
Session Recovery: Convenient to continue balancing from where you left off.
Tolerance Calculator (ISO 1940): Calculation of permissible imbalance according to the ISO 1940 standard.
Grinding Wheel Balancing: Special mode for precise balancing of grinding wheels.
Graphs:
Overall Vibration Graphs: Visual representation of overall vibration.
1x Vibration Graphs: Displays the vibration characteristic at the main frequency.
Harmonic Graphs: Displays harmonic components of vibration for detailed analysis.
Spectral Graphs: Detailed graphical analysis of the vibration frequency spectrum.
Additional Features:
Archive: Saves the results of balancing for future use.
Reports: Creation of detailed reports on balancing results.
Repeat Balancing: Simplifies rebalancing thanks to saved data.
Production Line Balancing: Suitable for balancing rotors in serial production.
Balanset-1A also offers flexibility in choosing between metric or imperial unit system, ensuring ease of use anywhere in the world.
Price: €1751
Balanset-1A Package Includes:
Interface block
Two vibration sensors
Optical sensor (laser tachometer) with magnetic stand
Weighing scales
Software (Note: laptop not included, can be ordered separately)
Plastic transport case
Advantages of Balanset-1A:
High Efficiency and Quality: Balanset-1A provides high precision and reliability of balancing and vibration analysis results.
Ease of Use: The device is easy to use and requires no more than 2-3 hours to master, even for those who are not experts in vibration analysis.
Customization to Client Needs: Balanset-1A flexibly adjusts to your tasks, allowing you to solve a wide range of balancing and vibration diagnostic tasks.
Affordable Price: Balanset-1A is significantly cheaper than market counterparts, making it an affordable solution for a wide range of users.
High Repeatability of Results: The device uses several "know-how" techniques that significantly increase the repeatability of amplitude and phase vector vibration measurement results, enabling the achievement of ensuring high precision and repeatability of measurements.
Conclusion
Balanset-1A is a powerful and affordable tool for balancing and vibration analysis, which will help you increase the reliability and efficiency of your equipment, reduce vibration and noise levels, and prevent accidents.
Order on Amazon
