7A-FTE Made in germany Hafkai`s Celica
Hafkai
Postautor: Hafkai » 21-10-13, 12:10
Finally my Celi is running again, this took quite a bit longer than i expected but i changed a lot on the car in this time. At the first start i got problems with the ignition and build a custom system with an Avensis distributor and some Bosch Coils wich works awesome. For now i got about 700km on the new engine, everything seems to be ok, no oil smoke or consumption, only the T28 turbo leaks a little bit, but nothing big.
Here is a video of one of the first successful starts 7A-FTE start and a test drive at night 7A-FTE test drive
And some updated pics of the car :)
Zewus
Postautor: Zewus » 21-10-13, 12:12
Nice job, what's about ECU?
Hafkai
Postautor: Hafkai » 21-10-13, 12:24
The ECU is a EMS Motorsport 6860 .. easy to tune and affordable, it lacks some settings especially for idle and lambda control but otherwise its a precise working ECU.
Greegg07
Postautor: Greegg07 » 21-10-13, 12:48
:roll: Emmm, a gdzie tłumaczenie jakieś?
KRYSO
Postautor: KRYSO » 21-10-13, 13:11
Greegg07 pisze::roll: Emmm, a gdzie tłumaczenie jakieś?
Np TU
copy - paste
[center]JEDZIEMY[/center]
Rzeski
Postautor: Rzeski » 21-10-13, 13:44
Hafkai pisze:Finally my Celi is running again,
Christian Good Job :)
What time you will arrive to Wroclaw again ?
Let`s meet and say big WoooW in real :)
What kind of petrol is engine set up ?
WROCLOVE BRADA
DZIK
Postautor: DZIK » 21-10-13, 13:54
Damn it ! great mod :) good luck in reaching
Bylo:
AT180
ST202
ST205
ST185 Carlos
Postautor: Makabra » 21-10-13, 19:42
I've seen this test drive video about one or two weeks ago, and Im pretty sure, I posted a link on our forum. Anyway, impressive job done :)
Hafkai
Postautor: Hafkai » 21-10-13, 20:37
Rzeski pisze:
Right now i tuned the engine to run with E85 Ethanol fuel. But its getting a problem at low temperatures, below 8°C the engine takes forever to start....
I will be in Wroclaw for a week at the end of November, but with my Audi. If there is a meet at this time you can write me a message :)
Next summer i will try to get to Wroclaw with my Celi, this will be hard since the cars suspension is about the stiffest you can imagine :roll:
Hafkai
Postautor: Hafkai » 30-05-14, 12:46
Finally back on the racetrack after about 3,5 years :) .. with a complete useless suspension setting but lots of fun ;) ..
Eurospeedway 21.04.2014
And a first dynorun with the new engine, the big torque spike is due to a slipping clutch...
